Front Parksense Unavailable - Service Required.
Tesla
My truck has said front parksense unavailable, service required since the beginning of the year. No sensors seem to be damaged or any wires that im seeing unplugged. Any ideas?
Tred's
Kansas City, KS
While traveling back from the left coast last year, I hit a bug right in the R hand outer sensor. As soon as I pulled off the freeway, I started getting those warnings. It took a minute for me to figure it out, but once the sensor was cleaned off, no more problems. Just a thought...
vincentw56
If no sensors or wiring are damaged, you could have a bad parktronics module. You will probably need to take it in to have it diagnosed.
Tesla
Put my scanner on it and it gave these codes
vincentw56
Looks like a wiring issue, then. You might need to trace it down. It could be hard to find depending where in the harness.
Tyler Schilling
What kind of scanner is that? Ive been looking for a scanner that can read parksense codes (and everything else) for my Ram Powerwagon. I have a different one but it will only read powertrain codes.
