Paragoptics anyone ?
OCD Solutions
I just received the glove box and center console LED's in True Blue. Anyone else get in on the pre-order of the new additions to the Ambient lighting kit?
2019+ 5th Generation Ram 1500/2500/3500 Overhead Console Ambient Lighting Upgrade + Upper Glove Box Compartment Courtesy Lamp (Pre-Order)​
OCD Solutions
Before and after. It’s subtle but so much better.
UnclJim
Long Island
trying to get that glove box tube in is killing me and my sausage fingers. Anyone in the Long Island area accomplish it? ill bring beer!!!!
Maloneyd
Did you ever get it in? I’m on Long Island I can’t get it in and I’ve been trying for hours.
UnclJim
Long Island
Nope haven’t tried in a couple days. I wasn’t wanting to change the glove box light itself but it might end up going that route to get the tube in. I still have to tackle the door panel ones as well
OCD Solutions
I don't recall having to remove the tube when I did mine. I went in through the vents and it fits onto the end of the tube.
OCD Solutions
Gotcha. I forgot they made a kit for trucks that didn't come with ambient lighting.
That tube and the glove box lamp would be the hardest parts, everything else should be simple after that.
UnclJim
Long Island
The glovebox isn’t getting done unless I can’t find someone with the right size hands to get the tube in …..lol
FM45
MA
@ UJim... not sure if you tried this way or not... with the radio pulled, slide the tube from the left to the right and have the top glove opened and with your other hand guide the tube into position... when it's in place there is a stop far right and it won't go any further... if I remember the flat side of the tube faces down and towards the front of glove, the tube sits in a couple a plastic supports...
-=FM45=-
boogielander
really interested but too bank for me at this moment. Maybe when I want to impress a girl and have some intimate time in the truck then I'll shell out the money to put it in to set the mood.
for now though, all my money will go to off-road mods.
UnclJim
Long Island
-=FM45=-
thanks I tied it once but was a little pressed on time at that moment going to try it again
OCD Solutions
That was my original plan but I took one look at the small driver boards and I knew my vision was not up to the task, nor was my patience.
Kpcert
I bought the glove box light with over the head console light. Taking apart the glove box made the tube a lot easier to install
Kpcert
For the over the head led light did you have an issue installing? I connected the white/green strip and the black like the directions say but still nothing. I hooked the led to a 9volt batter to make sure it works and it does. Any ideas?
UnclJim
Long Island
havent gotten around to it
OCD Solutions
I didn’t have any issues but I don’t remember the details of the install. What type of connection did you use?
