Door Lock Knob Thread Specs?
Rick3478
NW OH
I haven't found anything to replace the door lock knobs that bite. :( I'm prepared to get some delrin rod and turn my own if necessary. Does anyone know the thread specs for the lock rod?
vincentw56
Remove the knobs and plug them. A lot of us have done that.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
There is a TSB on them. New design for the plastic "button" that is on the panel.
I just un-screwed them about three turns.
Waiting for the wife to fly in from Finland for the Christmas, I`ll let her test out my solution.
edit: Front door grommet retrofit. Bulletin # 23-039-21.
Rick3478
NW OH
Thanks for reply, but I have the TSB and my grommets are already the new design. Marginal improvement that doesn't cure the problem IMO. The sharp channel rings molded into the knobs have no reason for existence that I can see other than to tear flesh. They are below the door panel when locked, so you can't use them to grip the knob to pull it up. The only time you could grip them is when the door is unlocked and you can only push down. I think they need to be taller to be useful at all, and definitely need to *not* have sharp edges anywhere close to that surface. If I can't come up with something better, I'll have to go with the plugs.
Idahoktm
North Idaho
These plugs from Ace Hardware work well.
HemiDude
Ohio
I was originally looking for black knobs bc I didn't like the silver ones that came with my Night Edition ( :rolleyes: ). I couldn't find any good replacements either, and ended up removing the knobs and plugging the holes. I think it looks better, really cleans up the door panel.
31RamIt
Where did you find plugs
HemiDude
Ohio
Hopefully you didn't spend too much. The 3/8" plugs I bought at Ace Hardware were 40¢ a piece.
Yeah, no reason to pay up for a set of you only need a couple. I always seem to be looking for fasteners like that , and I'm sure the set I bought wasn't pricey, so it made sense for me.
31RamIt
Oh, I'll cancel it and find cheap ones. Are they 3/8" for sure?
I think I'm going to take the grommet out too so it is just flush and not two layers. Anyone have a measurement for the hole without the grommet?
HemiDude
Ohio
Does the grommet hold the door panel material in place there?
Idahoktm
North Idaho
Yes, 3/8" fits nice and tight.
MannyN
Thye are not knobs as the 60's and 70's cars for locking and unlocking the doors. Today, they are merely indicators to see if the doors are locked or not.
