275/60/20 on oem 20'' wheel?
Tlaug01
Anybody know if a 275/60/20 will fit on stock suspension (no air susp.) without any issues? Looking to get wildpeak at3s on the oem 20 inch wheels.
Plenty of guys are running that size...myself included with the same Falkens you’re looking at. No issues at all with fitment here. (y)
I have those on my laramie 4x4 ccsb. fit fine. ride smooth. quiet
I have a cpl. pics of truck but am unable to attach because file too large..
maybe this will work
Curious what the gain is for this slight change? Other than your truck will show about 3.3% low on the odometer which could come in handy if you're leasing....
Extra ground clearance if you go off road. Even 1/2 inch extra can mean the difference between clearing a rock or other obstacle. Peeling back a differential cover and losing the lube, can make for a very bad day. Street dwellers usually do not worry about clearance issues.
Mine on Les Schwab Open Range 275/60r20. No issues whatsoever. Planning on going a little bigger next time with a 2” level. Waiting for Bilsteins...
Dumb ? But do a lot of people go off-roading with the oem 20 rims and tires
thinking about going with falken 275/60 but debating on going with some black 20in or do the 18... It's my first 4x4 but I plan on hitting lots I can see 20 on 35 but scared of 20 on 33
Okieeeee can someone enlighten me on tire sizes since I don't have a freaking clue. I have on my Laramie 20". 275/55/20 falken wildpeak A/T. can I safely go up to let's say from 55 to a higher number which I would think would give me a higher wall?
