They took a couple days to get back to me. It’s great that a few of us are sending emails about it. Maybe that’ll be incentive for them to continue making them.email sent to T&S. Awaiting reply...
What are you asking?so...what I gather is a tune to shut off the EGR??
Yes, you would have to do a tune to shut off the EGR. The GDE tune does use the low pressure loop of the EGR where it can and reduces gunk in the intake, but the EGR stays on with this tune.Yeah sorry. Lol. What I meant to ask was - a tune is really the only way to shut the EGR off without a delete and not throw codes?
what you gonna get ? im after rhe rebel 2500 if it comes witb blk red interiorI did also. I turned it down since I’m not keeping this truck long-term, so that opens up one for someone else.
TRXwhat you gonna get ? im after rhe rebel 2500 if it comes witb blk red interior
Here's what the T&S Speed Shop catchcan looks like:
The PCV hose gets interrupted by the fittings up top. There's a machined port on the top for a sensor.
At the bottom is a ball valve to drain it.
Here's a shot of the side:
Sweet: a viewport. I'm not sure how well that will work, once oil gets into the catch can, but I'm glad to see it there.
I'll install it sometime after the 19th. I'm headed out of town.
(The bottom of the ball valve is threaded. Perfect! I'm going to add a fitting and drop a length of tubing down. I'll secure the tube as needed. I'll add another valve to the bottom of the tube. To drain the catch can, I'll open both valves: the one at the catch can and the one at the bottom of the drain tube I'll add. I'll put a valve at the end of the drain tube because I don't want residual drips staining my driveway or garage.))
My initial impressions: this thing is a precision built beast! It has some heft. There's nothing here that seems like it's delicate or will break. The tightness of construction, fit and finish, are outstanding. Two thumbs up so far.
C3k, it looks good. Really interested in hearing how it works. Keeping my fingers crossed that it doesn’t throw any codes.Here's what the T&S Speed Shop catchcan looks like:
