Not there, but I did have a slight seep from around one of my coil packs on valve cover. Was fixed under warrantyAnyone else have a oil leak problem? I noticed some oil leaking between the engine and transmission. Anyone have a similar issue ?
I’ll take a closer look at my valve covers. Hoping it’s not my rear main seal.Not there, but I did have a slight seep from around one of my coil packs on valve cover. Was fixed under warranty
are you still under warrantyI’ll take a closer look at my valve covers. Hoping it’s not my rear main seal.
Any word on what it was ?I'm bringing my truck in on October 4th. Will report back. Hope it isn't the rear main seal. I've ruled out the oil sensor or residual oil from filter or spilt oil while filling.View attachment 139994View attachment 139995
Yes I am. Taking it to get checked out next week let’s see what they say.are you still under warranty
Still awaiting final report.Any word on what it was ?
so they think its grease leaking?Got truck back today. They removed the transmission and saw assembly grease all around the bell housing. They removed it and I'll monitor now
Reviving this thread…Yep. They showed me the pictures of the transmission. Flywheel slung the grease to the housing in a perfect circular line.
Yes everything is bone dry underneath.Reviving this thread…
did you have this issue resolved ?
was it in fact assembly lube?
I’ve had a small drop or two of brownish fluid where the engine/transmission meet for a while. It’s not engine oil and not green like the 8 speed ATF.
Mine is a ‘24 with 6K miles.
thanks in advance
