Dusty1948
I haven't found a concrete answer...or really any semi-firm answer even on this. I've read the 3.21 is a little "ho-hum" off the line, but the 3.92 would be significantly better. Does that rear end cause a noticeable drop in MPG, either city or highway?
Although my '19 only has 7180 miles on it as of this writing, I believe I'm beginning to see a pattern.
I have the fuel consumption records for my two previous 4th gen Rams that had the 3.92 axle. I have been comparing those to the fuel consumption of my '19. Although I think it's still a little premature, I appears that the 4th gen Ram 1500s got slightly better fuel mileage around town than the '19. This became especially acute on my current tank as I've been doing a lot of around town Christmas shopping and I'm seeing less than 17 MPG, compared to both the 2010 and 2014 during the same period of comparison (low of 18.04, 18.67). That low a MPG never occurred on either 4th gen until the real low temperatures of January/February.
Technically, this would make sense as higher throttle pressure is required to launch a vehicle with a numerically lower axle ratio.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Now at: 007180 miles.
