 - Jun 8, 2021
- Solutions
 - 1
SubtleWell I appreciate all the responses, definitely a good site to have joined. I will go ahead and order a WDH and put this behind me.
				Seriously? That is actually a thing?
Yeah my wife's already on the huntI've seen several listed on FB Marketplace for half the price of new, some look pretty new.
They have a bit of a following among the class A RV crowd where people tow big trailers with big buses. My concern is that they take tongue load off, but don't do much for the yaw stability problems that can arise from towing a big trailer with a smaller vehicle.Seriously? That is actually a thing?
Yeah my wife's already on the hunt![]()
Being totally new to this, if my payload is 1331lbs, do I subtract that from 12000 or is there another equation involved?
I have the tow package, 392 rear end, & lsd.
Thanks for that...I also found out that RAM's website will provide towing capacity via VIN # which came up with the 9800lbs.7,200 lbs (GVWR) - 1,331 lbs (payload) = 5,869 lbs (curb weight)
15,600 (GCWR) - 5,869 = Your Max tow capacity of 9,731 lbs
I tow my boat and snowmobiles without a WDH, but they don't weigh anywhere near your trailer weight. However, the key is to have everything level. So many people tow things where the tongue is angled down and then the front wheels of the tow vehicle are pulled up. That's a great way to get into a wreck when an emergency jumps out at you.Ultimately, you'd like to have both truck and trailer close to level, and a WDH will help you do that.
this is pretty cool.
Agreed...that is why I adjusted it as high as I could and made it level as possible. The fact that I tow it 40 mins within city/little hwy limits, I just cannot justify buying a WDH for that. If I ever plan to take it up the interior into the mountain passes, a WDH will be a must.I tow my boat and snowmobiles without a WDH, but they don't weigh anywhere near your trailer weight. However, the key is to have everything level. So many people tow things where the tongue is angled down and then the front wheels of the tow vehicle are pulled up. That's a great way to get into a wreck when an emergency jumps out at you.
When towing a new setup, I always throw a level on the tongue to make sure it is level. You can even download phone apps that will acts as a level. Adjustable trailer hitches, or just using the right drop on a standard hitch, will work for most situations. Heavier trailers really benefit from the WDH. Just always make sure that you are level.
A lot can happen in 40 minutes with an unsafe setup.Agreed...that is why I adjusted it as high as I could and made it level as possible. The fact that I tow it 40 mins within city/little hwy limits, I just cannot justify buying a WDH for that. If I ever plan to take it up the interior into the mountain passes, a WDH will be a must.
But that's the point I am trying to establish...how is it unsafe? The Curt hitch I use allows me to level out the trailer...it's rated for 14klbs...and my truck can tow 9800lbs. Just because I don't have the sway bars on? I ensure that the two days I tow it out of the year that the weather is not inclement and road conditions are clear.A lot can happen in 40 minutes with an unsafe setup.
I didn't say it was unsafe. I commented on the belief that only 40 minutes makes it OK. I don't know what you're pulling or what your weights look like. Put your truck and trailer on a scale, and that should answer your question.But that's the point I am trying to establish...how is it unsafe? The Curt hitch I use allows me to level out the trailer...it's rated for 14klbs...and my truck can tow 9800lbs. Just because I don't have the sway bars on? I ensure that the two days I tow it out of the year that the weather is not inclement and road conditions are clear.
