Rough Country M1 adjustable leveling struts
this seems to be new.
Mostly 2" and under a lot of people keep the stock uca's but the mopar 2" lift uca's are the most inexpensive out there and have more travel angle than the stock uca's
Just installed on my half ton; paired them with a set of V2 monotubes in the rear and swapped my rear springs (Laramie, no Ram Box) to a set of Ram Box ORP springs. truck feels nice and tight, will be getting aligned tomorrow and the 295/60R20 Toyo AT3 mounted as well. Only a few miles on them so far. But truck feels firm/tight. Doesn't seem to waller around on bumps anymore either. No long term here yet, but i'm happy so far. Install was a breeze.
Here she sits. 2” M1 front. ORP Ram Box springs in rear for an inch. On 295/60R20 Toyo AT3 rubber. I do have a 1/4 spacer as well. Only bent the Mopar bracket for the front flaps a touch on the insides. Rides great!
Nice! I ended up going with the Bilstein 6112’s and 285/65/20’s on a 0 offset. Looks good!
Bilstein makes good stuff. I went RC to give them a go. I plan to do Carli. But after the HVAC replacement and such it wasn't happening and my tires were toast haha. So far, Kit is great and no issues. Rides nice, Firmer and more sporty feeling. But not harsh. Some of that is being on a Load E tire...not at all uncomfortable though
did you add the 1inch in the back because the 2inch M1s would sit higher in the front than your stock back?
