How to set up weight distrubution hitch
Jonz
I got a trailer a few months ago that came with a weight distribution hitch. It just dawned on me that I'm not 100% sure it's set up correctly. Previous owner had a 2015 f150 I think. I'm sure it's atleast close to being where it needs to be for my truck. The few times I've towed it did fine. But anyone know how to redo it and what to look out for? I've never set one up. I do have aftermarket airbags to help with squat if that matters. Any info helps. Thank you.
Get the manual from your hitch manufacturer online and just go thru the setup again. It won't be the same from a different truck make to Ram. Your airbags covered for you, so it's not an emergency.
There are likely youtube videos for your specific hitch. Otherwise, the manufacturer's website usually has such things available. Two big things...Airbags are NOT a substitue for WDH, and CAT scale at your nearest truck stop is your friend.
Years ago when I was in your situation, I ran across a post that explained it like no other. Not only did it make more sense once you thought through it, but it made the rig look and drive perfect. I still cringe when I see folks driving around with the truck squatting and the trailer end way up in the air.
From memory:
  1. The hitch height levels the trailer. Adjust it until your trailer is level.
  2. The WD hitch angle levels the tow vehicle. It should wind up being the same pitch F/R with the trailer attached as it was unloaded. After step 1 is complete, change the hitch angle to level your truck.
  3. Changing one will impact the other so repeat all steps as needed until everything is level.
No idea where that post was but here is one roughly similar: https://davidsrvtips.blogspot.com/2009/02/hitch-setup_2781.html
Adjust the WDH to get the truck and trailer level with the trailer loaded, with the airbags empty. Then air up the bags until they just start to help.
The WDH bars should be relatively level/parallel to the trailer frame, too.
The Weigh Safe hitch is the easiest to set up of any hitch I've had any experience with. You can adjust the tension with everything hooked up. So you can dial it in exactly..
AirLift says to add air to bags prior to hooking up to trailer. Thoughts?
Someone within the past couple of weeks CALLED Air Lift and they said it didn't matter when you add air, posted in another thread here.
I did call them, they said to add air 35-45 PSI prior to hitching to the trailer, then adjust as necessary after hitched.
Your WDH should be setup without any assistance from the airbags. But yes, once you are ready to tow, put some air in them before you put load on them.
