jimothy
I wanted a true full size spare to match my Fuel Blitz 18x9 with Yokohoma Geoland X-AT 295/70R18 tires, so I plunked down a big ol' hunk o' cash to get a matching wheel and tire. My plan is to go to a five-tire rotation, so this blunts the pain by effectively extending the lifespan of my tires by 20%. At least, that's my excuse.
I've got two issues, the first being that the tire doesn't fit under the bed, even deflated to 30 psi (I could try going lower, but I don't think it'll make much difference). 295/70R18 works out to 34.3", but the X-ATs are oversized, which a published 34.6" diameter. That extra 0.3" may be all that's keeping the tire from fitting. Nonetheless, I think I can make it work, even if it involves grinding down the hitch receiver a bit.
The second issue is the one I'm more concerned about: The hub bore diameter of Fuel wheel is 106.1 mm vs 77.8 mm stock. The spare tire hanger is meant to fit the stock bore, of course. I'm able to hoist the Fuel wheel (aside from the fitment problem), but it looks a bit precarious. When hoisting the stock spare, the hanger more or less automatically centers itself, while on the Fuel where, you have to carefully center it, and even then, it lifts unevenly.
What do you think of these possible solutions?
- Hub centric ring to hold the tire in place on the hanger. I'm thinking of an aluminum ring with a lip.
- Replace the entire spare tire hanger, cable and all.
- Use some sort of adapter for the exiting hanger to make it fit the larger hub bore.
- Don't sweat it; once I have the tire hoisted with enough tension, it's going to stay in place.
