TSL
I have a small utility trailer, single axle, 8x5. Weighs ~ 800 lbs empty and has a GVWR of ~ 2900 lbs. I've towed it a lot with my '07 Subaru Outback XT which handles it fine. Truth be told, a couple of times I've probably had more on it than I should have done with the Subaru towing it, especially since it doesn't have brakes. I've also towed it behind our '15 Toyota Highlander which manages it very well. Loads like 15 x 120lb hay bales, loads of firewood from out of the forest etc.
I've had my truck since late June ( my first truck ) and finally got around to getting a ball mount so I could tow the trailer. I got a B&W adjustable ball mount with 1" to 7" of drop. My measurements proved correct, and with the ball mounted at the 7" drop position the trailer looked nice and level behind my Rebel. I will admit it also looked a little silly behind the Rebel
, being as small as it is. It did really look very small behind the truck.
The real point of my post here is that when I went to back up with the trailer....oh my goodness, I'm a newbie all over again ! I can back that trailer effortlessly behind my Subaru, because I can see it very well. I can back it reasonably well behind the Highlander where I can't see it quite so well, sometimes I get one of the kids to stand in the back corner so that I can see the back of the trailer in order to see better which way it is pointing. The Highlander does have a backup camera but it doesn't do me a whole lot of good I find when backing the trailer. It's too low to be useful. I am aware that short, single axle trailers are harder to reverse, but I'm just amazed at how totally different it handles behind the truck. Basically it jackknifes if you breath wrong ! Very small and frequent nudges left and right on the steering seem to be what's needed to keep it moving the right direction. The camera on the truck is more helpful, being higher up. Actually, the trailer being so small, assuming it's not loaded with a yard of crushed rock or 15 hay bales, taking it off and turning it by hand is probably easier !
One another point / question. So the truck seemed to know it had a trailer behind it. It's a 4-pin flat connector, no brakes as I mentioned, but obviously the truck is aware there's a connection made because a trailer icon lit up in the instrument cluster. However, when I went to back up I got a nice demonstration of the rear parking / obstacle detection. The truck decided the trailer was an obstacle i was about to back into and slammed on the brakes and stopped me. OK, so I now I know that feature works I said to myself, but....there's got to be some way for it to not do that when a trailer is connected ! I searched around through menus looking for a way to tell it there's a trailer there ( which as I said it seemed to know because the trailer icon was lit ), but couldn't see anything, so eventually I just flicked the rear park assist toggle switch off so I could actually back the thing up. Is that the only way to do it or am I missing something ?
In summary, maybe I need a bigger trailer now that will look better behind my truck and be easier to reverse ! Or I can just put the hay and the firewood in the bed of the truck I guess ! ( But it's so nice and clean back there, seems a shame to chuck firewood in it
