Anyone have Mopar part #'s for door handle & map pocket ambient led assy ?
mike_ct
Looking to ad the ambient led's to my interior door handles and map pockets..both areas have a rectangle recess where it would be installed..I know I could do with generic led's but was hoping for mopar part numbers..I couldn't find a breakdown of a 2019 door panel assy. on the usual mopar parts sites I use.
You think there's wiring to those locations? Following
If you find a kit please let us know, I would be interested if it isn't too expensive. I know that @jamesfg has a write up on adding ambient lighting for his Rebel (this will likely be my summer project). :)
I couldn't find anything on the interweb to get the parts. In addition your going to run into an issue with pocket above the door handle as there is no indentation on where the LED should be located. It's way less expensive to just DIY it plus you can add more lights if you want to.
interesting, I didn't pull the door handle, but I do see a rectangular hole above the door handle, and also above the map pocket areas..are you saying it doesn't go thru though?
Post up a pix would ya?
