Air Ride Suspension Links Measurements
eithkrp1
I have the Revel LInks on my 2020 RAM Limited Air Suspension, and i want to be able to take the rear back to stock, and adjust the front to just a 1/2" up. Problem is the shop lost either the front or rear, so i don't know what the factory length is and not sure i can order replacements separately.
Does anyone have or can measure for me the length from the center of the fitting hole on the factory links? Or know where i can find it?
Thanks....
Could probably find it here:
@ferraiolo1, @Rock Crawler, @outnumbered, @1LowTrk all have good info posted in a few of the different threads on the 1st page of the suspension category in the forum here.
When is Mopar going to release a d*mn rear level drop kit to make life easier?! 🤦🏽‍♂️ Sorry, I just ran out of patience over the years lifting my Cherokee several times. Looking for the easy way. Lol
Thanks....
Eithkrp1,
Attached to this reply you’ll find pictures of the factory links place above a tape measure.
One is 3.25 inches and the other is 3.75 inches.
Simply remove your revel links and adjust them to match the lengths shown in these pictures. I don’t have a caliper to give you exact measurements (center of eyelet to center of eyelet) for you but this should be very close.
***THIS IS A GUESS*** but I believe from factory, the larger links goes to the front and the shorter links to the rear.
Eithkrp1,
Thanks, that's a big help. Was the 3.25 and 3.75 from end to end? I did find one set, so i can match that up and then determine the which is which.
I saved my original links and they're labeled front and rear.
I can measure the rears later today if you want.
I have pictures attached. It’s from end to end.
