It's all plug and play. I honestly couldn't believe how dumb dumb proof it was. Dust covers fit over bulb as well. High beams were simple and so were fogs. Laid under front of truck and it was right there. Low beams were the most difficult but pretty simple. Remove air box on passenger and on driver side I removed one bolt holding a wire harness to give me another inch. Both sides are still really tight but it's doable without removing much of anything. Hope that helpsWhen you replaced all the bulbs with Auxito, Was it true plug and play? Did all the dust covers fit back on? How bad was the job, did you have to go through the wheel wells?
