Hello ladies and gentlemen i have a 2015 ram 1500 5.7 hemi and my temps get pretty hot i think, coolant running 80mph gets to 230 and oil will get to 248 any ideas on what i can do. Thank you!
Yep...if you're driving 80 on flat highway and not towing...those are high temps.
It's rare for a thermostat to go bad, but they do.
Also rare for a radiator to clog, but they do.
Water pumps go bad, too.
I'd think it's most likely one of those.
Get it up to temp, bring it home and keep it idling. Use an imaging IR camera (if you have access to one) or temperature gun, and check the temps on the hose leading INTO and OUT OF the radiator. While it's sitting there idling after driving it to get the temps up, the hose leading into the radiator should be pretty close to the temperature on your temp gauge. (You can also aim the temperature gun at the block and at the oil pan to get those temps.)
With the engine running while parked, and those temps, the radiator fans should be blowing (on the highway, at 80 mph, the airflow won't need the fans). The hose OUT of the radiator (usually the bottom hose) should be significantly cooler than the hot, in, hose.
If the INTO hose is not hot, but your engine is, then it's a thermostat (or possible water pump) issue.
If that hose is hot, but the outflow from the radiator is just as hot, then it's a radiator/fan problem.
All of the above is off-the-cuff and worth exactly how much you paid for it.
