Start of 2022 Production.
Found 1122 Window Stickers tonight. None of them were forum members.
Nothing likely, the VINS built today ranged from 118 to 422 with the majority of them in the 404-406
Where are you getting those numbers from in the vin?
I’m trying to figure out when my truck might go into production.
Good luck trying to figure out when your truck might go into production. There is no rhyme or reason on how they're building these. I have a low 32XXX VIN on a Limited Longhorn, order placed on March 1st and I just got notice a couple weeks back that my truck has finally been 'scheduled' to be built with an estimated completion of beginning of August. I have limited to no faith that will happen, but I guess we'll see.
so from what I can tell, ask your dealer for a POC...or if the truck is in D1 status, and what the ESD is...which is usually the expected build date if it's in D1.
That can also change though as well.
Those are digits 12-14 (out of 17). They represent groups of 1000. The 2022 VINs started at 100000 (the 100 group) and are currently being assigned in the 425000's (the 425 group).
Thanks for the reply. I’m 415 so hopefully it will be started soon.
I have the POC and the truck is only in order confirmed stage.
so won't know anything until you get into D1 status., limited's get built quicker than anything else.
Probably doesn't matter which trim it is at this point of the 2022 cycle. They are probably wanting to finish up 2022 builds and get the 2023s going.
It will be interesting to see what models get the digital display, my bet would be on Longhorn and up.
