327V8Hemi2020
- May 1, 2021
Took less than 5 min and you don’t have to remove anything….
Yep, I think I Remember removing the bottom knee panel and then from there reach up behind the switch and squeeze. Should pop out. Keep the silver trim ring and reinstall on the new switch.I saw Water Fowler's video on this, so you just remove a couple of screw on the kick panel below the steering wheel, reach in and access the switch from there right?
Looks good, I think I will do this as my next mod.
I did this yesterday, didn’t have to remove any panel, just stick my hand under the dash. It took me a couple of tries to grab the switch but once a go hold of it came out easily. 5 mins tops.Yep, I think I Remember removing the bottom knee panel and then from there reach up behind the switch and squeeze. Should pop out. Keep the silver trim ring and reinstall on the new switch.
NOOOOOOOOOO….Just reach up all the way and squeeze the 3 points to release it and push it forward,,,unplug and plug new one in…snap back into place….5 min…don’t have to remove anything…I saw Water Fowler's video on this, so you just remove a couple of screw on the kick panel below the steering wheel, reach in and access the switch from there right?
Anyone with the night edition have a picture of it zoomed out so that you can see it in relation to everything being dark?
I just can't decide if I like the red or the black more for the dark interior.
