- Apr 11, 2019
The rear view camera is only used to calibrate and operate trailer reverse steering control.My truck shows a trailer connected indicator on the dash even when using a 4-pin on a small utility trailer. I had always thought it was detecting the trailer through the 4 pin plug. Are you saying the trailer is detected by the rear view camera?
The only way a trailer can be detected in order to automatically shut off the rear park assist system, and to use the factory integrated brake controller, is if some type of resistance is going across the 7-way trailer connector’s brake feed and ground pins.
There is no telltale indicator that shows a trailer connected to either of the trailer connectors, but there is a telltale showing trailer disconnected if you plug a 7-way in, and disconnect it while the truck is still running.
What you are seeing is the indicator for trailer merge assist, and it has auto detected a trailer behind you in order to extend the blind spot further back. Nothing needs to be plugged into either trailer connectors in order for this to happen. In fact, if someone is tailgating you while driving on a tight winding road, such as in the mountains, trailer merge assist will auto detect the tailgater as a trailer, and that light will illuminate.
