jeffjcalweb
 - Apr 4, 2022
Hi  - are any of you that have done the halogen to LED swap (not just bulbs, the entire assembly, VLAN, Morimoto, etc) - are you also updating any vehicle configuration settings using AlphaOBD?
I'm just curious because I know there are menu options for changing the light type in those locations to LED - so I'm assuming there's a reason you can change parameters, but not finding anything in any install videos, emails to vendors, that says if you should update or not.
I know the install is physically, for the most part, plug and play. Just curious if there's an extra step that should be done if someone has AlphaOBD and is comfortable making config changes.
