33gallon tank
Prattp1996
Does anyone make the bracket for adding the third strap on the 33 gallon tank?
Sal731
Didn’t know we needed to add an extra strap to the gas tank. I’m assuming however it is mounted can support the full weight of a full tank of fuel
Prattp1996
I currently have the 26 gallon, has two straps the 33 gallon has three some truck came with the beam from factory for third strap , my truck didn’t.
Sal731
Hmm. Learned something new today. Never checked how many straps on tank. Next time I slide under there I’ll take a look
LaxDfns15
Memphis, TN
Huge thread on adding the tank, and I'm pretty sure I've read about either welding the bracket on or retrofitting one.
Prattp1996
I was reading somewhere, there is a guy that makes the bracket, just was hoping he’d chime in!
Aseras
from here
part number is 52030458AB
Prattp1996
That’s the part number for the beam for the last strap?
Aseras
Crawl under the truck and look for this
if you have that tab, all you need is the strap and a bolt to secure it.
Prattp1996
Unfortunately I don’t have the spot for the strap
Aseras
This is an option if you want it. Several guys are running without it.
skidplate crossmember retrofit
tolh13
My diesel 33-gal tank only has 2 straps and is not molded to have 3.
