Shifts And Grins Fab
I'll get this started so it's documented. Full disclosure, this build will be slower going than I'd like but you guys will see prototype parts here before they are released. Some may never be released. I'll try to do my best to document where all of the parts came from as well, hint, most will be from Shifts And Grins Fabrication. To start with, I installed our Ditch Light Brackets and Diode Dynamics SS3 lights. I built my own harness for the lights because I didn't have one on hand from Diode Dynamics and I had all of the parts to build my own harness. I will be swapping these lights out with either SS5 pods or SS3 Max pods. I'll probably install some SSC1 Pods to the sides as well. I also had the entire truck done with PPF. The roof was done matte black, the lower black portion of the truck was done in matte (Stealth) PPF and the silver was done in gloss. The next two things I will do is install our reverse light kit and then figure out and make instructions to mount a Diode Dynamics 30" light bar behind the lower grill of the front bumper. After that, it will be prototype and Test and Evaluation parts. There is a lot on the list. You all will have to follow to see where this goes. I will be doing a prerunner theme on this build.
