Tilting side mirrors
Toperz
5thGenRams Supporter
Stratford, CT
Hi all.
So recently I switched my side mirrors with mirrors from limited edition. Everything works fine like blind spot monitoring, blinkers, heating, power folding except tilting in reverse. I've turn that feature on using AlfaOBD and shows on my screen but can not turn it ON. Am I missing something??
Thanks
Hi all.
Thanks
Might require different door modules.
Problem solved.
For some reason it didn't switched in AlfaOBD : Doors: Passenger Memory Mirrors Present --> Yes.
Also I've swiched : Electro-chromatic passenger mirror present --> Present(it was off)
Now to the next mod.
Problem solved.
Does your truck have memory seats/mirrors or does the reverse tilt work without memory option?
It doesn't have memory seats. Tilt works without that option.
cool..I tried enabling that a while ago, and never got it working.i'll have to go thru alfaobd again and see if I missed something.
did you just change BCM settings, or did you have to change anything in the door modules?
Just changed BCM settings, nothing was done with door modules.
Hi all.
Thanks
Could you please share a link for the AlfaOBD you use. Thank you
What you mean?
If this is what you asking, I'm using AlfaOBD for android, OBDlink MX+ and Kaodtech security bypass.
