I bought some aftermarket rims. I couldn't quite get my caliper gauge in there, but the wheel opening is about 106 mm. The ram hub center is 83 mm. I can't seem to find any hubcentric rings to fit. Thoughts? Necessary?
Every time I've bought wheels from Discount Tire (4 times now) they give me a set of rings with them. I've never bought them separately.Just google it. I never seen the rings before. I have ran aftermarket wheels on car before, but never heard of these rings. Dose everyone runs these with aftermarket wheels?
I've never run them before with aftermarket wheels and I've never had a problem with vibration.Just google it. I never seen the rings before. I have ran aftermarket wheels on car before, but never heard of these rings. Dose everyone runs these with aftermarket wheels?
Most people do not understand that almost all OEM rims and lug nuts are lug centric, including the Ram. Rings were used back in the days of Cragar style multifit slotted lug stud holes to fit different bolt circle sizes. With the Ram being lug centric, the lug nut taper centers the wheel. There is no need for hub rings unless you are using slotted rims and flat lug nuts and washers. The clamping force holds the wheel securely concentric in all driving situations.What are the reasons of the rings?
This was my thoughts. The lugnuts, being conical seat will take care of it. and center them. Ive never needed to use them in the past due to fitting on the hub, or the lug nuts. As you stated, I've had a set of old school cragar (those things freak me out. haha) and needed the special washers. My kids hyundai needed rings, but the lugnuts were flat faced.Most people do not understand that almost all OEM rims and lug nuts are lug centric, including the Ram. Rings were used back in the days of Cragar style multifit slotted lug stud holes to fit different bolt circle sizes. With the Ram being lug centric, the lug nut taper centers the wheel. There is no need for hub rings unless you are using slotted rims and flat lug nuts and washers. The clamping force holds the wheel securely concentric in all driving situations.
Different lug styles:
Acceptable installation, look close, the hub is flat black, the wheel ends with gloss black. The Silverado also comes OEM with tapered lug nuts:
That's not right. The OEM Ram wheels are hub centric as are most OEM wheels.Most people do not understand that almost all OEM rims and lug nuts are lug centric, including the Ram. Rings were used back in the days of Cragar style multifit slotted lug stud holes to fit different bolt circle sizes. With the Ram being lug centric, the lug nut taper centers the wheel. There is no need for hub rings unless you are using slotted rims and flat lug nuts and washers. The clamping force holds the wheel securely concentric in all driving situations.
That's not right. The OEM Ram wheels are lug centric as are most OEM wheels.That's not right. The OEM Ram wheels are hub centric as are most OEM wheels.
Disinformation warning!Most people do not understand that almost all OEM rims and lug nuts are lug centric, including the Ram. Rings were used back in the days of Cragar style multifit slotted lug stud holes to fit different bolt circle sizes. With the Ram being lug centric, the lug nut taper centers the wheel. There is no need for hub rings unless you are using slotted rims and flat lug nuts and washers. The clamping force holds the wheel securely concentric in all driving situations.
That all sounds a bit strange. Wheels usually have a chamfer in the back side of the hub hole and centering rings may have a little shoulder to fit into the chamfer and prevent the ring from migrating away from the hub. If you put such rings in backwards it can make a mess similar to what you describe. Whether mis-design or mis-assembly, it sounds like someone did something wrong.I've had some recent problems with Hub Rings.
My after-market HELO rims have 106mm wheel openings. I bought some 106mm to 78mm hub rings.
The wheel hubs have slight indents machined into them between the 78mm hub and the lugs.
It looks like the hub ring manufacturer attempted to fill this indent with a spacer (possibly to make the hub rig stronger?), but made it too thick.
The result was that the hub ring acted as a small wheel spacer, actually holding the rim away from the wheel hub.
When my dealership rotated the tires during routine maintenance, and torqued the lugs down super tight with an impact wrench, the hub ring splintered around the edge. Those shards now sat between the wheel hub and the rim and caused significant runout, so much that the truck shook at certain speeds.
I took the hub rings off and threw them away. Now the ride is back to normal.
I'm letting the tapers on the lugs hold the rims centered and it seems to work fine.
I believe the stock hub is 77.8. I’m running at 78.1, not enough to even warrant a ring. No issues at all.I bought some aftermarket rims. I couldn't quite get my caliper gauge in there, but the wheel opening is about 106 mm. The ram hub center is 83 mm. I can't seem to find any hubcentric rings to fit. Thoughts? Necessary?
