Which Fumoto valve????
FourByBud
I have a 2022 1500 5.7 ETorque 4x4 with the swaybar right at the drain plug. What Fumoto valve are people using?
None. I just attach a short hose to it and drain away.
This one.
It is adjustable so you can change the angle of the outlet. I also just put a hose on it to drain. Super clean and easy to use.
This one.
This is the one I bought. Haven't received it yet, but will install it on my first change. Also bought a hose kit. And a nipple cover for a little more insurance in case the valve drips.
I've had it on for about a month without a single drop of oil.
This is what I bought. Started with just the valve. First oil change after installing the valve and realized I needed the hose as well. Didn't hit the sway bars but the stream of oil hitting the drain pan splattered everywhere Screenshot_20220516-161500.png
Another Fumoto SX series user. Very happy with it after 3.5 years of use. If only the oil filter could be handled so nicely!
