deeve
Hello, looking to get a bed extender and want one that fits under the factory soft cover. I think the MOPAR one will. How hard is it to remove the extender though if/ when I want to?
As mentioned in post #4 you rotate it up and lift out, quick and easy. Plenty of YouTube videos showing assembley and use bed extenders.I think there is some confusion on the part I am talking about...I am referring to the Bed Extender vs the Bed Divider...
This thing is what I am referring to.
I could be wrong, but I think the particular bed extender you are talking about is only for the Rambox beds. I like that idea a lot and have looked. I cannot find it for the regular beds. Unfortunately.The RAM OEM Divider works as both an extender and divider. And the divider is more squared off vs the rounded edge.
Thank you, it was answered. Pretty easy for sure! I did not think of searching youtube for assembly instructions. Good idea. The post you mentioned was just to clarify for others what I was talking about.As mentioned in post #4 you rotate it up and lift out, quick and easy. Plenty of YouTube videos showing assembley and use bed extenders.
Too bad. It looks like a really good idea. I wonder why there isnt something similar for regular beds?deeve - yep, you are correct. Rambox beds.
I just mounted mine over the spray in and it works fine.I've got a question, it looks as if you have the spray in bed liner. Were you able to put in the brackets to swivel the extender over the spray in liner, or did you have to clean out a spot for the brackets to fit more tightly to the bed rail? Thanks for your assistance.
Thanks Much, appreciate it.I just mounted mine over the spray in and it works fine.View attachment 131900
