AngelPhoenix
Halifax, PA
What kinda car wash. Ever noticed any issue with the black and scratches. Since everything shows I been scared to use the local wash.
It's called ModWash, Mechanicsburg, PA. Them and a few other types of washes (Cloud 10 is another one) use rotating "brushes" but the bristles are made of a rubber and foam combo, so it's almost impossible for them to scratch you.
MurphBigHorn
Cool. I’ll check them out. And compare my local wash. Ty
BowDown
Frisco TX
Well that was anti-climatic
20220508_203043-jpg.128960
Step must have a 3.92 ratio
LS-RR
NH
Installed OEM LED headlights and OEM foglight last weekend, installed Passive Entry this weekend. Both are great mods!
Soulkeeper
OH
Happy Monday, just picked my truck up this AM with a new set of Wrangler Duratrac! I'm on stock 275/65R18 and suspension, look at all that open space! If ya ask me, next time I'm going to look into the possibility of going from 33's to 35's.
HEMIJAKE
Potter County, Pa
Made a trip south for conference last week. Tried my first full tank of 88 octane e15 since it was 30 cents cheaper than 87 e10. Fair bit of time idling in construction traffic and 75+ mph blasting on the highway, so all in all, not bad. I was forced to park under pine trees though. So a full wash, decon, and coating is in order.
Your tires are only 32's right now. So, yeah, at least step up to 33's. Won't fit 35s up front without a lift/level
Belvedere
Made my first trip with the camper and Airlift 1000's. I would say it handled pretty good. Rear dropped about 3/4" with 40psi. May try a little more next time. Forgot to measure front. Will try with the WDH eventually as well. Will probably eventually add the Hellwig, but I do think the bags helped a little with sway, trailer or not. 20220506_173800.jpg
theblet
Looks like you have 32’s right now. 33’s would make a difference. I just did this and looks a lot better I think.
AngelPhoenix
Halifax, PA
Made my first trip with the camper and Airlift 1000's. I would say it handled pretty good. Rear dropped about 3/4" with 40psi. May try a little more next time. Forgot to measure front. Will try with the WDH eventually as well. Will probably eventually add the Hellwig, but I do think the bags helped a little with sway, trailer or not. View attachment 128979
What're your numbers with this setup?
Seabass4592
Would look better with the Husky wheel liners installed. Bought them for about $100. Easy install and come down lower than the molar ones. Cleans up that whole area.
