Kay AUXITO
AUXITO LED
Hi guys, your 2019-2020 Ram 1500 are LEDs already? Feel free to leave your comments and insights.
Through AUXITO's many tests on the LED bulbs, we customized the kit for the 2019-2020 Ram 1500. However, the 2019-2020 Ram 1500 and Classic are not exactly the same size.
The following are their sizes and features.
2019-2020 Ram 1500
● High beam: H11/H8/H9 - 8000LM/bulb, CAN-BUS Error-free
● Low beam: 9005/HB3 - 8000LM/bulb, Plug & Play Installation
● Fog light: H11 - 4000lm/set, Cool White/ Amber Yellow/Ice Blue,1:1 same light filament position
● Front turn signal: 7443 - 1600LM/PC, Amber Yellow/White, Dual-color Function
● Backup light: 7443 - 1400LM/bulb, 6000K Xenon White
● Brake light: 7443 - 1600LM/PC, Brilliant Red
● Map/license plate/front side marker light: T10/194/168 - 240LM/PC,Cool White/Amber Yellow
● Dome light: 41mm - Built-in intelligent IC driver for optimal lamp performance
2019-2020 Ram 1500 Classic
● High beam:9005- LMP Chip - Newer Technology than CSP
● Low beam: 9005(with projector headlamps) - 8000LM/bulb, 360-Degree illumination
H11/H8(without projector headlamps) - 8000LM/bulb, Plug & Play Installation
● Fog light: 9140/9145(with horizontal fog lights) - 4000LM/set, Cool White & Waterproof
9006/HB4( with vertical fog lights) - 4000LM/set, Easy Installation &1:1 Safe Beam Pattern
● Brake/ turn signal light: 3157 - 1600LM/PC, Plug and play easy installation
● Backup/reverse light: 921(without projector headlamps) - 2600lm/Pair, 6000K Xenon White
7443(with projector headlamps) - 2600lm/pair, Non-polarity, plug-n-play
● Side Marker light: 3157 - 1400LM, 360 degree
● License plate light: 921- 2400lm/pair, Non-Polarity Designed, just plug and play.
● Dome/ map light: 41mm - 6000K xenon white, All aluminum body design for better heat dissipation
We would like to pick 3 guys to review our LED light bulbs, anyone interested in reviewing them? Feel free to leave your comments or like us.
Here's the package of AUXITO LED bulbs for 2019-2020 Ram 1500 (Tradesman, Big Horn, Laramie, Rebel, Laramie Longhorn, and Limited)
Here's the package of AUXITO LED bulbs for 2019-2020 Ram 1500 Classic
In addition to the above kits, AUXITO has custom kits for other years of Ram 1500, please click here! If anyone has any insights on LED upgrades, feel free to leave your comments.
2019-2020 Ram 1500
