Start of 2022 Production.
Getting a build sheet means they have gone down the main assembly line, I also check the trucks for Window Stickers and once they have a window sticker then the truck has been invoiced to the selling dealer and is ready to ship.
Morning, so getting a build sheet means it's completed the build process or starting it? I'm trying to connect build sheet with a specific build code. BS = Code I is completed erc.
Huh, I'm not finding it on my BS. What's the term on the BS for it?
Well, lol maybe I looked at the wrong one. 🤦🏻‍♂️ I could’ve sworn last night I saw it, I may have been half asleep as well. I have been seeing it under the optional equipment section though.
My understanding was that in Laramie Level II, it won’t be there, but it would have been there for Level 2.
Build sheet means it’s fully built. From there it goes through inspection, then shipping and the window sticker becomes available.
BS means it has finished the main assembly line, you will go to accessories after that for items like bed liners, etc if required by the spec. THen you will com eback to the facotry for inspection, shake down, emmisions, etc. and once you pass final QC the truck will be invoiced to your dealer, sent to shipping and a Window Sticker posted.
1144 Build Sheets found today. 10 more forum members with trucks starting production! Congratulations to @Limited_Ram, @GR1MREAPER, @911dispatch428, @truckyou, @Ninety-9 SE-L, @GrumpyDUB, @Swampy, @bobinwa, @Haneyrm, @MidnightExpre$$
NICE MEMBER COUNT TODAY !!
VINBSWSBStoWSSTATECOLORSERIES
306994 @Limited_RamXLouisianaGraniteTRX
316478 @GR1MREAPERXIowaPatriotLimited
321263 @911dispatch428XNorth CarolinaSilverLaramie
325440 @truckyouXOntarioBlackBig Horn / Lonestar
328690 @Ninety-9 SE-LXLouisianaGraniteLaramie
328742 @GrumpyDUBXCaliforniaGraniteRebel
328744 @SwampyXMissouriRedBig Horn / Lonestar
328861 @bobinwaXWashingtonGraniteLimited
328866 @HaneyrmXFloridaSilverLimited
332623 @MidnightExpre$$XNew JerseyPatriotBig Horn / Lonestar
SWEET !!!!!
I’m traveling today, no chart from me.
Wasn't expecting that! 7 days off their estimate. Not bad! Thanks triple_b!
That was an I not a 1 but was just something used as a reference not my situation. Just wondering if BS meant how it is going to be built at the start of the line or how it was built at the end of the line
I personally don't know what my buil status is, I know the original SD was 4/21, then 4/27 and is now 5/5.
Now I need to find time to analyze the Build Sheet . . .
Tyty
Day 27, +1 to the average of VA, since my limited longhorn WS posted, and 25 days since I confirmed KBZ status with the dealer. Given that tracking is still down, I am assuming that my truck is just as likely to randomly show up before I actually get an ETA. Patiences.....any day now is the assumption......
I'm on day 32, +7 to the average of CA. Patience is running out.
I overlooked it at first on my bs. Run a control/f using "reclining" on the bs. Hope it's there for you.
Sweet I'm in there.
So, my build sheet is above.
As I mentioned earlier, my POC clearly states Laramie Level "2"
My BS states Laramie Level "II"
The reclining rear seats are nowhere to be found :(
I might contest it and get my $100. I believe they are doing that.
What other differences are there between the 2 and II?
