High beam headlight issue
lemyers49
I have a 2020 RAM. My headlights operate normally on the low beam but will not switch to high beam when the turn signal stem is pushed forward. The lights flash to high beam when toggled rearward and return to low beam when released as normal. The dealer says they will have to schedule a service appt to even check it out.
Anyone have any suggestions in the interim?
Goldsy
Check the lights settings to see if your auto high beams are enabled, they will remain off if it detects another vehicle in front of you or coming towards you. You can turn that feature off. That might not be the issue, but just getting the obvious one out of the way.
lemyers49
Thank you for your suggestion.
photog0611
What did the dealer determine the cause of your high beam not working on the forward position, but working on the reverse (flash) position? I am having the exact same problem on my 2021 Ram 1500. I have turned off the auto-dim feature for the high beams with no effect. Thanks!!
Ducky5
You can also try to change the headlights from "auto" to the fully on position, if that works I would suspect something with the auto high beams.
My '22 Limited and '15 Laramie both had auto high beams. They wouldn't come on if I wasn't going under maybe 10mph.
