One new sensor and lots of time playing with Alfa ODB:
Replaced the humidity sensor with one that also does rain sense for the windshield wipers
Programmed rain sense wipers, auto dimming brights, off-road pages, fog light dropout, and modified the setting on my heated seats and steering wheel.
Does alfa have the ability to adjust the rain sensor sensitivity? My automatic rain wipers seem to come one too early for me and stay in the low speed position instead of simply wiping when necessary even when set at the longest delay
I read through this thread and someone mentioned that their might be a way to calibrate the rain sensor.
Pretty sure there’s a calibration you can run with AlfaOBD. I never bothered to look into it since they work fine when it’s actually raining.
Thanks, I'll have to look into that. My wifes Jag XF has rain sensor and it works perfectly, a engages the same but once its cleaned the windshield, it stops
Where was that from? I’ll order today. Lol
Of all places AutoAnything.com - The check ...after payment...said delivery in JUNE !! So I contacted Hellwig and they said it takes 10-12 Weeks to make them. Then they said contact onw of their suppliers.
SD Truck Springs
Summit Racing
Hellwigproducts.com
Contacted and cancelled the order and then today it showed up without warning - Go figure - The Easter Bunny Has Delivered 11
Did you install it yourself? If so, did you replace the gel pack? Some have had issues when not replacing the gel pack. There isn't any adjustments in AlfaODB. At least I couldn't get it to work.
Installed a Bak Revolver x4s tonneau cover.
Does that have the rotating side rails that hold the slats down?
I thought that was an interesting idea, how is it working for you?
I'm interested in hearing how it turned out.
Just installed the Revolver X4s tonneau cover. Super easy and took me less than an hour, with half that time spent modifying the rails to work with the right on brackets.
I thought that was an interesting idea, would like to hear how it worked out for you.
  • Back
