I have the nav, but don't use it. I never thought I would use Android Auto, but I like using Google Maps for navigation through Android Auto better than the built in nav. Even though I can only use half my 12" screen for Android Auto, I didn't use the full screen for the built in nav, so I didn't lose anything. Not sure the limitation of the screen size for the 8.4" screen, but it's worth a try.2022 Laramie with 8.4 uConnect 5 without Nav.
Is it possible to flash the system to add Nav, or is the hardware different?
Ya, I purposely ordered the truck without Nav. I have other cars with Nav and CarPlay, and I always end up using the phone rather than the GPS. I was just wondering if there was a way to enable it. I found out after delivery that you lose the voice command function if you don't have Nav. While also completely unnecessary, it would be kind of fun to play with.I have the nav, but don't use it. I never thought I would use Android Auto, but I like using Google Maps for navigation through Android Auto better than the built in nav. Even though I can only use half my 12" screen for Android Auto, I didn't use the full screen for the built in nav, so I didn't lose anything. Not sure the limitation of the screen size for the 8.4" screen, but it's worth a try.
There’s more to it than just a software flash as the nav radio is HD. Without nav you also lose the ability to access the off-road pages as I found out the hard way.2022 Laramie with 8.4 uConnect 5 without Nav.
I also have the 8.4 non-Nav. I use android auto a lot. After several months I figured out that we actually do have voice control - have to press AND HOLD the voice button on the steering wheel. Your google assistant will activate.Ya, I purposely ordered the truck without Nav. I have other cars with Nav and CarPlay, and I always end up using the phone rather than the GPS. I was just wondering if there was a way to enable it. I found out after delivery that you lose the voice command function if you don't have Nav. While also completely unnecessary, it would be kind of fun to play with.
And I believe it is smart enough now to download them ahead of time - but if not, can be done manually. Completely non-issue.Google maps has offline maps. Cellular data is a non factor then.
