30" Light Bar Help For A Customer
Shifts And Grins Fab
5thGenRams Vendor
5thGenRams Vendor
Gilbert Arizona
Hello all. Thank you in advance for taking the time to read and help if you can. If you are running our brackets to mount a 30" light bar in the lower grill of your Ram Truck, we'd love to see as many pictures as possible. We are especially looking for photos of Limiteds. We have sold lots to customers with Limiteds but I don't have very many photos of them and none from the front. Thank you all for the help. PS the issue the customer is having is he said his light bar is sitting at the bottom of the bumper grill opening instead of the center of it. All of the pictures I have of other trim lines (I don't have any of Limiteds) it appears the light bar is centered in that opening. A picture of WaterFowler41s truck for reference.
Just out of curiosity is there a chance that customer flipped the brackets around on mistake? When I was messing around with mine trying to fit them in the custom spots I had to flip the brackets around and ran into that problem, bar sat way to low in the grille. They were still on the correct side driver and passenger wise, but were basically rotated 180 degrees.
That was my original thought but I got on a video chat with him and best I could tell he had them on the correct side and the correct orientation. I was wondering if the Limited lower bumper grill sits slightly higher or something. It isn't an issue any one has mentioned before. We have sold hundreds of sets but only recently started tracking trim levels from the customer.
Ever have some one install a 30in curved light bar? I have the light bar and grill for my
Laramie
It looks like the lower valance in the bumper is slightly different on the Rebel vs the Limited as you can see by the bottom line of lower grill in the pic. If you send me some measurements I can take some of mine for reference if you want @Shifts And Grins Fab , maybe from the bottom of the front upper trim piece to the top and bottom of the lower grill?
They may be somewhere between 1/2" and 3/4" difference. It looks like from the only picture I have received so far of the Diode Dynamics 30" Light Bar with our brackets, the light bar sits about flush with the bottom of the opening as opposed to centered on other trim lines.
Any info on the fact the brackets will fit a 22 Limited?
What would be your pick? The Diode Dynamics 30" or the Rough Country 30" light bar which is way cheaper.
thanks in advance.
thanks in advance.
It will work on a '22 Limited. The light bar will sit at the bottom of the opening instead of centered in it. I prefer the Diode Dynamics light bar but I'm sure the Rough Country bar is cheaper.
Do the lights and brackets work on Ecodiesels?
I don't believe they will due to the intercooler
We haven’t tested them on the eco diesel. If you can send me a photo of the backside of the bumper and under the front of the truck, I should be able to tell you.
My local dealer told me they can quickly get hold of this lights which are similar or perhaps better than the Rough Country ones.
I assume they will fit the S&G brackets too cause the length is 765mm so 30,12 inch? But what about the other dimensions?
Somebody btw has experience with this brand?
I'm not familiar with that brand. I can not say if they will work with our brackets or not as I have never seen them.
