Shift & Grins Lift Link
wsutard1
@Shifts And Grins Fab would you lift link work in the rear? I have a limited with off road package. I want to level it out by lowering the rear a bit. I would do the front. It the standard setting for the Off Road package is using Off Road #1. So there isn’t much more upward I can go before I hit Ofd Road #2.
We can make links to lower the rear. If you place an order just make sure you leave a note that it is for the rear and you want to lower it. We always recommend slight adjustments (as little as possible to achieve your goal) front and rear to keep the best ride possible and still maintain the full function of all levels.
Thanks for letting me know. Will make note when I order.
Wow, I re-read my post. Makes me sound like an idiot. I swear all those typing mistakes weren’t in my original.
