Grinding noise after turning truck off - need help locating it
greenlawnracing
Twice in the last week I've pulled in the garage and turned the truck off as per usual. I heard a grinding noise - not horrific - that lasted about three to five seconds.
The first time I thought it was the running boards, but as I type this I don't know what made me think they were deploying yet. Perhaps I had opened the door already. The second time I heard it as the seat was going back, so perhaps that was making the sound.
Anyone have a similar experience? Would like to actually pinpoint it so I can advise the dealership accordingly.
evanxrs
Is it your air suspension adjusting. Happens all the time with the air suspension.
Sent from my Pixel 6 Pro using Tapatalk
greenlawnracing
Could be? I usually put it in the lowest position when I pull in the garage. I did hear it "blow off" the other day too, been a minute since I heard that noise. But it certainly sounds more like a grind, does the air suspension making a grinding noise?
BowersFJ
Sounds more like a fuel pump thing …. I get it too, and I do not have air suspension
Lpsouth1978
Do you have the E Brake set to automatically engage? Took me a bit after getting my RAM to realize what I was hearing. I ended up turning it off in UConnect.
BowersFJ
Sounds possible …. Just a screen setting ?
BowersFJ
Nope, not that …. My auto engage is off
greenlawnracing
My auto engage is also off. I will try to remember to record every time I pull in there garage for a while
theblet
Mine makes a noise after shutting off too. No air suspension. Gonna check auto engage setting today
