Soooo, I got to install Switch Pros SP9100 to manage the leds on my Rebel. Have had switch pros light controllers on my last 3 trucks and definitely love them. The Bluetooth capability and all programming options.
Followed installation location from Hammerdown motorsports youtube video(link here). I assume he is a member here but don't know his nickname to tag him. Instructions on how to remove center console from here (link to forum post). While I was at it I realized it was way easier to just remove the part were you are going to install the switch pros controller than to actually take the whole console out. Purchased the controller and module mount from SDHQ.
For the module side, using the SDQH module mount made it a breeze. Although the plugs end up in the way if you have to remove the battery, but you just disconnect them and there is plenty of space to remove the batt. Pulled all the controller wiring through the drivers side grommet and into the center console.
The center console area is where it gets tricky. Just loosen the center console following the instructions so that you can pull it back a couple of inches enough to remove the phone/wireless charger area. No need to take the whole center console out of the truck. Trim the area with the provided template. That area has a back panel so yoou need to trim that also, either use a long dremmel bit(I did) so that both plastic panels get trimmed or trim from the front and from the back. (no pictures sorry, was more concentrated on cursing and trimming the area).
This is the final result. Very happy with it. No button inserts yet as I have not wired the LED bars, pods, etc to the switch and don't know on what position they will end up. If you have any questions feel free to drop a message.
