Is a Hub Centric Ring needed for a 78.1 wheel?
MikeyHo808
Hawaii
My new wheels have a center bore of 78.1. Is a ring still needed for such a small gap of .3 mm?
I have called a few local shops, and have gotten mixed answers, just adding to the confusion.
Thank you in advance. Aloha.
.3 mm is about 12/1000 of an inch. 3M electrical tape is .007. You wouldn't even be able to wrap the hub once with tape and make the wheel fit!
See, that’s what I said, but then I called a reputable shop on island, and they guy I was talking to was like “you have to have hub rings”…
Again, seems logical, but for .3 mm…?
Hub ring isn't needed for any lug centric wheel and lug nuts, assuming that's what you have. Some people like them to help you get a heavy wheel centered before you start the lug nuts.
In this pic, you need a ring for the lug nuts labeled flat face Ford and mag type. All others are lug centric and do not need a hub ring.
Not actually mine, but I had the exact same install. Notice the large gap between wheel and axle boss. Lug studs center enough for the tapered nuts to properly engage.
