ORG Front Springs on Non ORG Laramie
RN12
Atlanta, GA
Have been thinking about having ORG front springs installed on my Non ORG Laramie to raise the front a bit and still have a slight rake. Should still have about a half inch rake I believe. Does anyone know if there is any problem with doing this or should it work out just fine? Ready to pull the trigger on it now if it should work. Again, only the springs, not using the ORG shocks.
ORG’s have different PN shocks, so ya better check into whether ya have to change them as well
I bought a set of rebel take offs here. worked out great.
Truck looks great! So the rear didn’t get any lift correct? And without the spacers you would have gotten around a 1 inch lift in the front?
Thanks.
Yes I did not install the rear springs so height did not change.
Yes 1" in front without spacer.
Plus if you find a rebel take off you get the better bilstein struts/shocks.
As stated above the shock PN is different for the ORG, but I don't believe you need it. However the truck would probably ride better with it as the dampening will change to match the spring. I put ORG springs on the front of mine but I also used Bilstein 5100 struts and lifted it up more, plus changed out the rear springs as well to Bilstein.
Awesome, thanks!
