Added some reverse lights today
Abesosa
Would you mind DMing links to this set up?
2019 Ram 1500 Limited Granite Crystal 4x4 with Off-Road Group and air ride
20% Cermanic Tint
USA Flag Decal on rear 5th Window
Xpel Door Edge and door handle Protection
5thgenalamode
Ravenna Ohio
20% Cermanic Tint
Can you drop us a parts list with links?
Parts list
MICTUNING Flush Mount Led Pods, 2Pcs 20W Flood Cree Led MICTUNING Flush Mount Led Pods,... https://www.amazon.com/dp/B078WNM3K9?ref=ppx_pop_mob_ap_share
7 pin t harness, I used this one CURT 56584 Replacement... https://www.amazon.com/dp/B007EA6WQU?ref=ppx_pop_mob_ap_share
5way trailer side wire harness, I just used this and cut it for my needs CURT 58550 Vehicle-Side and... https://www.amazon.com/dp/B001EOV2X0?ref=ppx_pop_mob_ap_share
Waterproof heat shrink tubing
Solder if soldering the wires or butt connectors
Wire harness tape
Zip ties
Ring terminal for ground wire.
External tooth lock washer for ground.
Richard320
I appreciate the writeup. I'm considering adding some discrete auxiliary reverse lights myself. I already ordered a wireless relay (Thank you @dannymcd for your writeup) and dummied it up with some scraps I had laying around and confirmed that it can be programmed into a Homelink button on the visor. It worked!
The auxiliary lights will come on anytime the reverse lights come on. Or I can trigger them with the Homelink to use as work lights or to encourage tailgaters to back off. 😊 The little keyfob that comes with the relay will also still work them. It might be handy when camping to be able to trigger some bright lights without having to get in the cab.
Here's the wiring. Colors only reflect what I had lying around in the junk drawer.
bucontrol.jpg .
MannyN
View attachment 123749 .
That just calls for a disaster. You striped the insulation way too far back, a little twist of the wires and you have a short.
Richard320
I believe I mentioned that I just dummied it up. Perhaps you should go back and reread what I wrote and not just look at the pictures.
I needed it powered to verify that the homelink programmer will work with the relay.
GP-TEK
Thanks for the info fren!!
GP-TEK
Oh wow. Thank you for your post. Sorry people have the need to put other people down. I personally appreciate your info and would wire accordingly to my standards.
GP-TEK
Why the hate? I understand constructive criticism but coño.. while I appreciate what you are saying, it could have been worded differently. God Bless.
MannyN
No hate here, just pointing out the obvious. Worded differently? No need to call me a vulgar word for a woman's vulva or vagina.👎
GP-TEK
Understood friend. You are trying to help out others. Apologies.
GP-TEK
Lol 😂 Coño means damn in certain parts. Good catch though! Again, apologies.
Sgschaer
GP-TEK
