Transmission falling out of Drive on downshift, blinking, displaying "shift to P" and back
c3k
Imagine designing an aircraft, the French Airbus, where the pilot and the copilot each have independent side stick controls. Neither can visually see what the other's control stick is doing. If the pilot pushes his stick full forward and the copilot pulls his control full back, there is no feedback to indicate that the two are inputting opposite control commands. And the computer processor makes a decision to hold full back stick as the copilot commands. And a perfectly good plane free falls 50,000 feet into the Pacific Ocean killing everyone on board.
And you take the same plane and do a low pass at an airshow. Applying full power the computer overrides you and says nope, we're going to land. And land you do about a quarter mile past the end of the runway in a heavy forest. The planes explodes in a ball of fire.
Umm...that's not really how it works or why those planes crashed. But, yes, they were both perfectly good airplanes and they did crash.
Snekpete
Maryland
Really?
Accident[edit]​
Rio de Janeiro
22:03, 31 May
Fernando de Noronha
01:33, 1 June
Last known position
N2.98 W30.59
02:10, 1 June
Paris
Expected at 09:10,
1 June
Approximate flight path of AF 447: The solid red line shows the actual route. The dashed line indicates the planned route beginning with the position of the last transmission heard. All times are UTC.
The aircraft departed from Rio de Janeiro–Galeão International Airport on 31 May 2009 at 19:29 Brazilian Standard Time (22:29 UTC),[3]: 21  with a scheduled arrival at Paris-Charles de Gaulle Airport at 11:03 Central European Summer Time (09:03 UTC) the following day (estimated flight time of 10:34).[57] Voice contact with the aircraft was lost around 01:35 UTC, 3 hours and 6 minutes after departure. The last message reported that the aircraft had passed waypoint INTOL (1°21′39″S 32°49′53″W), located 565 km (351 mi; 305 nmi) off Natal, on Brazil's north-eastern coast.[58] The aircraft left Brazilian Atlantic radar surveillance at 01:49 UTC,[3]: 49 [59] and entered a communication dead zone.[30][3][failed verification]
The Airbus A330 is designed to be flown by two pilots, but the 13-hour "duty time" (the total flight duration, as well as preflight preparation) required for the Rio-Paris route exceeded the 10 hours permitted before a pilot had to take a break as dictated by Air France's procedures. To comply with these procedures, Flight 447 was crewed by three pilots: a captain and two first officers.[60] With three pilots on board, each pilot could take a break in the A330's rest cabin, located behind the ****pit.[61]
In accordance with common practice, Captain Dubois sent one of the co-pilots for the first rest period with the intention of taking the second break himself.[62] At 01:55 UTC, he woke up First Officer Robert and said, "... he's going to take my place". After attending the briefing between the two co-pilots, the captain left the ****pit to rest at 02:01:46 UTC. At 02:06 UTC, the pilot warned the cabin crew that they were about to enter an area of turbulence. About two to three minutes later, the aircraft encountered icing conditions. The ****pit voice recorder (CVR) recorded sounds akin to hail or graupel on the outside of the aircraft, and ice crystals began to accumulate in the pitot tubes, which measure airspeed.[63] The other first officer, Bonin, turned the aircraft slightly to the left and decreased its speed from Mach 0.82 to 0.80, which was the recommended speed to penetrate turbulence. The engine anti-ice system was also turned on.[64]
The aircraft's vertical stabilizer after its recovery from the ocean
At 02:10:05 UTC, the autopilot disengaged, most likely because the pitot tubes had icing, and the aircraft transitioned from "normal law" to "alternate law 2".[65] The engines' autothrust systems disengaged three seconds later. Bonin took manual control of the aircraft, using the command language, "I have the controls." Without the autopilot, turbulence caused the aircraft to start to roll to the right, and Bonin reacted by deflecting his side-stick to the left. One consequence of the change to alternate law was an increase in the aircraft's sensitivity to roll, and the pilot overcorrected. During the next 30 seconds, the aircraft rolled alternately left and right as he adjusted to the altered handling characteristics of the aircraft.[66] At the same time, he abruptly pulled back on his side-stick, raising the nose. This action was unnecessary and excessive under the circumstances.[67] The aircraft's stall warning briefly sounded twice because the angle-of-attack tolerance was exceeded, and the aircraft's indicated airspeed dropped sharply from 274 knots (507 km/h; 315 mph) to 52 knots (96 km/h; 60 mph). The aircraft's angle of attack increased, and the aircraft subsequently began to climb above its cruising altitude of 35,000 ft (FL350). During this ascent, the aircraft attained vertical speeds well in excess of the typical rate of climb for the Airbus A330, which usually ascend at rates no greater than 2000 feet per minute (10 m/s). The aircraft experienced a peak vertical speed close to 7,000 feet per minute (36 m/s; 130 km/h),[66] which occurred as Bonin brought the rolling movements under control.
At 02:10:34 UTC, after displaying incorrectly for half a minute, the left-side instruments recorded a sharp rise in airspeed to 223 knots (413 km/h; 257 mph), as did the integrated standby instrument system (ISIS) 33 seconds later.[68] The right-side instruments were not recorded by the flight data recorder. The icing event had lasted for just over a minute,[69][70][3]: 198 [71] yet Bonin continued to make nose-up inputs. The trimmable horizontal stabilizer (THS) moved from 3 to 13° nose-up in about one minute, and remained in the latter position until the end of the flight.
At 02:11:10 UTC, the aircraft had climbed to its maximum altitude around 38,000 feet (11,582 m). At this point, the aircraft's angle of attack was 16°, and the engine thrust levers were in the fully forward takeoff/go-around (TOGA) detent. As the aircraft began to descend, the angle of attack rapidly increased toward 30°. A second consequence of the reconfiguration into alternate law was that the stall protection no longer operated, whereas in normal law, the aircraft's flight-management computers would have acted to prevent such a high angle of attack.[72] The wings lost lift and the aircraft began to stall.[4][page needed]
Confused, Bonin exclaimed, "[Expletive] I don't have control of the airplane any more now", and two seconds later, "I don't have control of the airplane at all!"[29] Robert responded to this by saying, "controls to the left", and took over control of the aircraft.[73][32] He pushed his side-stick forward to lower the nose and recover from the stall; however, Bonin was still pulling his side-stick back. The inputs cancelled each other out and triggered an aural "dual input" warning.
At 02:11:40 UTC, Captain Dubois re-entered the ****pit after being summoned by Robert. Noticing the various alarms going off, he asked the two crew members, "er what are you (doing)?"[32] The angle of attack had then reached 40°, and the aircraft had descended to 35,000 feet (10,668 m) with the engines running at almost 100% N1 (the rotational speed of the front intake fan, which delivers most of a turbofan engine's thrust). The stall warnings stopped, as all airspeed indications were now considered invalid by the aircraft's computer because of the high angle of attack.[74] The aircraft had its nose above the horizon, but was descending steeply.
Roughly 20 seconds later, at 02:12 UTC, Bonin decreased the aircraft's pitch slightly. Airspeed indications became valid, and the stall warning sounded again; it then sounded intermittently for the remaining duration of the flight, stopping only when the pilots increased the aircraft's nose-up pitch. From there until the end of the flight, the angle of attack never dropped below 35°. From the time the aircraft stalled until its impact with the ocean, the engines were primarily developing either 100% N1 or TOGA thrust, though they were briefly spooled down to about 50 percent N1 on two occasions. The engines always responded to commands and were developing in excess of 100 percent N1 when the flight ended. Robert responded to Dubois by saying, "We've lost all control of the aeroplane, we don’t understand anything, we've tried everything".[32] Soon after this, Robert said to himself, "climb" four consecutive times. Bonin heard this and replied, "But I've been at maximum nose-up for a while!" When Captain Dubois heard this, he realized Bonin was causing the stall, and shouted, "No no no, don't climb! No No No!"[75][32]
When Robert heard this, he told Bonin to give him control of the airplane.[3] In response to this, Bonin temporarily gave the controls to Robert.[32][75][3] Robert pushed his side-stick forward to try to regain lift for the airplane to climb out of the stall. However, the aircraft was too low to recover from the stall. Shortly thereafter, the ground proximity warning system sounded an alarm, warning the crew about the aircraft's imminent crash with the ocean. In response, Bonin (without informing his colleagues) pulled his side-stick all the way back again,[32][3] and said, "[Expletive] We're going to crash! This can't be true. But what's happening?"[75][32][3][76][29] The last recording on the CVR was Dubois saying, "(ten) degrees pitch attitude."
The flight data recorders stopped recording at 02:14:28 UTC, 3 hours and 45 minutes after takeoff. At that point, the aircraft's ground speed was recorded as 107 knots (198 km/h; 123 mph), and that the aircraft was descending at 10,912 feet per minute (55.43 m/s) (108 knots (200 km/h; 124 mph) of vertical speed). Its pitch was 16.2° nose-up, with a roll angle of 5.3° to the left. During its descent, the aircraft had turned more than 180° to the right to a compass heading of 270°. The aircraft remained stalled during its entire 3-minute-30-second descent from 38,000 feet (12,000 m).[77] The aircraft struck the ocean belly-first at a speed of 152 knots (282 km/h; 175 mph), comprising vertical and horizontal components of 108 knots (200 km/h; 124 mph) and 107 knots (198 km/h; 123 mph), respectively. All 228 passengers and crew on board died on impact from extreme trauma and the aircraft was destroyed.[78][3][76]
cristi
Am avut camionul înapoi timp de cinci zile și... BINGO - a ieșit din nou din viteză în timp ce se oprește. Am terminat! Va găsi un avocat de lămâie și va iniția procesul de răscumpărare/proces. Aceasta este a PATRA oară când camionul este în serviciu pentru această problemă. TERMINAT!!!
Had the truck back for five days and... BINGO - slipped out of gear again while stopping. I'm done! Will find a lemon lawyer and initiate the buy back/law suit. This is the FOURTH time that the truck has been in service for this issue. DONE!!!
me too
ITGuy2020
So day 1 since I got my truck back. Hooked up the BlueDriver sensor this morning and took my truck in for an oil change (unsure why the dealer didn’t notice the "Change Oil Soon" light and ask me if I wanted an oil change while I had it in for service already). Performed the live monitoring for about 20 miles. The Control Module Voltage never went below 14.129V. Average was ~14.3V. Taking it on a longer run tomorrow and will see what happens.
c3k
Really?
Accident[edit]​
Rio de Janeiro
22:03, 31 May
Fernando de Noronha
01:33, 1 June
Last known position
N2.98 W30.59
02:10, 1 June
Paris
Expected at 09:10,
1 June
Happy to take this offline. Your summary was off. Your understanding of Airbus flight controls is off. Your understanding of the training and procedures is off. Yeah, I know something about this subject. Yes, two flight-worthy aircraft crashed. Yes, Airbus does some weird things with their logic. Send me a pm and I'll be happy to point out some things.
Let's keep this on-topic.
(Seriously, if you're interested, pm me. No emotive context, just a desire to get better information out.)
cristi
please bring information about the truck not the planes, I sued I want all the money back and moral damages, my life and the family is endangered dodge you will pay dearly if you do not make a recall
Buckeye Nation
You have filed a lawsuit? I have a lemon lawyer ready to go, but I want to give Stellantis and Mike McDonald a chance to do the right thing. He's been above board with me and I believe him to be a good guy. Dealer has also been good. They just don't know what's wrong.
Snekpete
Maryland
I find all of this quite disturbing. If I were king of the RAM I would give you a brand new RAM in exchange for the malfunctioning one. I would then take the malfunctioning one back to my R&D team and get the engineers to wire the truck up with all known recording and debugging tools. I would then have them drive the truck until they can figure out what is wrong. Doing this on a few dozen trucks cannot be a significant expense for FCA. This is just **** poor management on their part. Good luck!
Buckeye Nation
Thanks!!
ITGuy2020
Well, I’ve had the truck back for a week and can’t get the problem to repeat. Every time I go on a drive, I hookup the BlueDriver OBD2 sensor in hopes to have it happen again. I’ve attached in my case what the dealer removed and what they saw pulling a current draw. I’ve put ~300 miles on it so far and haven’t noticed the Control Module Voltage dip below 14v, except when the engine of off, which I would expect. [mention]Buckeye Nation [/mention] I’m still not convinced that the issue has been resolved and hoping you’re making some headway with Stellantis. They reached out to me again to let me know they are still working on it oblivious that I’ve already picked up my truck and had it back for a week. I asked her to keep the case open. So, other then me replacing the battery, the dealer removing the 3rd party GPS and Keyless Ignition Node, there has been no other parts replaced. View attachment 122040
Buckeye Nation
My truck hasn't repeated the issue either. It happened once and I've been trying to initiate a slippage by quickly decelerating and letting up on the gas pedal - but nothing. However, this is what I experienced when I first purchased the truck new. It happened every couple of months. Then, it gradually increased in frequency and culminated last summer when it was happening sometimes eight or nine times in a day. That's when my odyssey with RAM began. Still working on the financial resolution with Stellantis.
ITGuy2020
My issue started happening about a year and a half ago, and come to think of it, it has happened more during the summer than anything else. Yeah, I’ve been trying to initiate it too, but to no avail. Really hard to pin this thing down. Even in the summer months I’ve had it happen once a day or every other day, but never multiple times a day like you’ve been experiencing. Even if I prove that the issue is caused by a drop in voltage due to a current draw, it doesn’t isolate it to a specific component.
DM2059
I have 35k miles on my truck and this has been a problem for me also. I believe it is temp related. I put my trans in M8 until I see the trans temp come up to the peak (normal) position. Works every day for me.
Buckeye Nation
Interesting. I always have mine at M8. The issue has happened to me cold, warm and hot. I've had it happen 7 times in one day when I was in the truck for 9 hours driving cross country. It's definitely a safety issue. I'll let you know once I have resolved my buy back deal.
djevox
VP of Creative Thinking
MD
Lol, whut
cristi
my lawyer was contacted I will change my truck with a new one in 2022 but I also asked for a 6 year warranty on the new truck and my lawyer thinks I will receive it
Buckeye Nation
Just got an email from Mike McDonald at Stellantis. He said he will call this week to discuss the next steps to buy back my truck. I also learned from the service manager at LACDJR that Stellantis is short staff and they are all swamped. Guess there are a lot of bad RAM/Chrysler vehicles out there.
mt65
The first time I took the truck in, they had it for a week and couldn't replicate it. They asked me to come in and drive it. The mechanic and I got into the truck, turned out of the dealership lot and within 20 seconds, it happened. I was shocked, actually. The mechanic said "Ok. That's it. Let's go back." I also have video of it - just after it happens - with the blinking light on the transmission dial, etc.
This last time the engineers put a "flight recorder" device on my truck and they drove it extensively. (Yes, I'm getting an extended warranty.) After a few days, they had collected enough data and determined what repairs were needed.
I am supposed to get the truck back today.
What was the repair? My 2019 limited is doing the same exact thing as well as lurching forward before it takes itself out of drive.
