We are referring to the lag that you have from start up. (Dead Stop) The truck no longer hesitates when you hit the gas pedal.Sometimes I just wonder by the statement "increased throttle response". Throttle is electronically controlled by the ECU thru the electronic throttle pedal. How does an intake changes electronic control?
Still don't get it. The ECU does not call for AIR. Air flow is a result of throttle blade opening and rpm's The ECU adjusts Lamda aka fuel ratio. You can have a filter surface area of a football field and it would not change this function.We are referring to the lag that you have from start up. (Dead Stop) The truck no longer hesitates when you hit the gas pedal.
This is an analog result of having more surface area on the air filter for the air manifold to receive air when the ECU calls for it.
For the driver this feels like increased throttle response, you no long have a delay between the pedal and the take off, therefore the experience is fluid.![]()
The ECU helps to monitor the MAF (Mass Air Flow) sensor. While the engine is running, the ECU uses this sensor to read how much air is entering the engine.Still don'
Still don't get it. The ECU does not call for AIR. Air flow is a result of throttle blade opening and rpm's The ECU adjusts Lamda aka fuel ratio. You can have a filter surface area of a football field and it would not change this function.![]()
Put a mask on you air filter.Just run an open throttle body, you will get 50hp. Its science.
