OEM verses Aftermarket brakes
HotHareSpey
Hey all,
My local dealer just bumped the price of brakes through the roof. Wondering if anyone uses aftermarket pads or rotors. I’m told the $500 difference is negligible in performance but may not get as many miles out of them
thoughts?
OldMarine
I do all my own brakes,(haven't had to do them yet on my truck though), and I NEVER use OEM stuff, way too expensive, and there is plenty of decent pads and rotors out there for faaaaarrrrr less $. I usually get 15-20% off from Advance.
Jeffjad
Southwest PA
I haven't had to change the brakes on a 5th gen yet so I can't speak to the complexity but I use R1 Concepts pads and rotors on all my vehicles. R1 might not be the cheapest (def cheaper than OEM) but by far the best brakes and rotors I have ever used. Link below......
ferraiolo1
North Central PA
OldMarine
don't know about the rears yet, but there is nothing special/complex about our trucks front brakes. You can pop off a wheel and replace the pads in under 10 minutes.
Scram1500
Power stop has good options, they perform much better than stock and are reasonably priced
I've used Power Stop rotors and pads on three different cars, great product (y)
cevans6318
South Florida
shop around on ebay or other online sites, can usually find OEM pads and rotors for half the cost that the dealer charges.
c3k
Power Stop rotors and pads on a 2007 Hemi. They are great brakes.
PurpleRT
Pads I usually go aftermarket and go ceramic. Rotors either oem or quality aftermarket bank rotors. I skip the whole drill/slotted but that’s up to you. Doubt there’s anything complicated about our brake system it’s not a Ferrari should be just like any other American vehicle. Now the electronics that I can understand being more complexed.
Whitty37
I'll just add to the above posters regarding Powerstops...I have never done brakes in my life and replaced all 4 rotors and pads with no issues. They are better than the OEM's and saved hundreds doing them in the home garage. Bought all the parts from Summit Racing as well...
UnloosedChewtoy
5thGenRams Supporter
South Dakota
After a ton of research last year, I swapped to Power Stop pads after contaminating my OEMs by accident. (Fixed my brake squeak while I was in there by replacing the pad retaining clips with quality pieces as well, and a little lube between them and the bracket.)
No issues, been over 6 months now I believe. Stop at least as good as the OEMs, and I reused the OEM rotors, as I had like 5k on them at the time. They’d be even better if I had replaced the rotors as well I bet, but I didn’t want to spend the money yet.
Scram1500
The only part of the job you need to be mindful of is the rear electric parking brake, there is a service setting for the rear e-brake acuator in Uconnect
