Hemi noise question, newbie
Brownan
I've got about 600 miles on the new truck. 5.7L eTorque with 3.92 gears. Never had a Hemi or a truck for that matter so perhaps this is a "they all do that" thing.
Under partial throttle, either maintaining speed, or lifting off the throttle I get this sort of weird "congested exhaust" noise. That is sort of the best I can explain it. Almost sounds like burbles and pops on a more sporty exhaust, but these sound muffled and given all the cabin insulation they are sort of in the background.
I can see that this truck would be really quiet without those burbles, but they're there, and they're sort of annoying. Does not do it under more loaded throttle application, or off throttle. Just maintenance throttle or coming off throttle.
Any ideas? TIA
Idahoktm
North Idaho
Yep, that's the MDS. Use the gear selector on the right side of your steering wheel to select 8th gear and MDS won't activate. You'll have to do this every time you shut off and restart your truck.
Nsleone
Florida
Like they said above ^ should be the MDS.
If you go into the settings on the main screen there’s an option for “fuel saver light” or something like that( forgive me I haven’t done it in a while ). It comes up as a little green Eco light near the top left of your center gauge cluster screen when MDS is on.
Brownan
Thanks all. I think exactly right that it is MDS. Should have figured that out myself.
eTorqueCoasting
I've never heard any difference with it turning on or off. Man, my ears much be worst than I knew
Idahoktm
North Idaho
I can only hear it if my windows are down and I'm driving by a reflective surface, like a building. I can mostly feel it. It makes the truck vibrate. I suppose if you had an obnoxiously loud exhaust, it would be pretty noticeable.
mikeru82
The Palouse
Yeah, it is noticeable with a louder exhaust.
Ramjack
Yep. To me it's a slight shudder. You won't feel it while coasting, but it increases with throttle load. Not much though because the MDS deactivates when there is any significant throttle load.
