The Poor Shifting Transmission Thread
I am experiencing a rough shift when decelerating and the truck shifts from 6th to 5th. Every time into 5th it lurches the truck slightly. I feel it has only started in the last 5000km . I now have 23000 kms on the truck. Also the other day for the 2nd time I had the issue where I shifted into drive and the truck would not go anywhere. Then after hitting accelerator pedal the truck lunges forward.
New here!
I’ve hade the pleasure, exempting gas mileage, of driving a 2021 Ram Big horn 5.7L Hemi. I’ve noticed this rough down shifting coming to a stop from 2-1. Kinda like a rolling over the break sensation with a slightly noticeable down shift. I have the 3.92 with as much bells and whistles (MSRP 53k with 10k of that coming in extras). On mine, I have the break control. I noticed today that my towing (excuse me, I don’t know truck language) gauge was set to +6.5. I haven’t towed anything since I got the truck in April. I set it to zero, and what do you know, my rough breaking magically stopped. Don’t know if that’s the solution but I’ve attached picture of what I’m trying to talk about.
P.S-I idle quite a bit so my mileage is pretty low in the picture. Please let me know if this fixes it. Once again, someone from the factory set it or maybe I bumped it, don’t know. All I did was keep on hitting the negative (-) button until it hit zero, road it for 50 miles in town and noticed a much smoother ride.
Try making sure you didn’t “accidentally” hit the gear limiter on the right hand side. If you see a D-1 on your shift gauge, keep hitting the positive button on the steering whee until you shift out of the gear limiter setting. You should see only the letter D. I hit by accident pulling out some times or turning and not paying attention to where my hand goes down at. It’s freaked me out not being able to shift out of 1st until I realized what I was doing one day. Hope this helps and if not, I hope you get it answered.
New here!
I checked mine today and it was set to +5. Why would it have it set if I never towed either? Even though I think this only controls your trailer brakes. Going to go out later and see if my downshift is smoother.
Had to post a thank you! The light electric trailer brake was set to +4.5 on my truck and I had the same strange shifting. I set it to 0 and after a couple days everything is calming down and the shifting has massively improved. Finally, a solution! I even had the truck at the dealer three days ago and they said nothing was wrong and simply reset the shifting learn.
One thing I noticed is the shifting has got better after my 3.5 SST lift. Maybe the angle that the driveshaft is at now works better?
Did this end up helping the shifting? I’ve noticed a change in shifting in the past couple weeks. More so in the upshift around 45mph, thinking that’s in the 5-6 gear range. It really revs over 2k rpm’s and holds that for a while, then shifts. I’ve used to be able to let off the Gas a bit and it would shift, but even doing that now won’t push it to shift.
I also noticed going down a steep grade today it would kick down a gear and the rpm’s would rev to maybe 2500. I know there is an element of engine braking, but this was a noticeable, uncharacteristic behavior.
I want to check this setting tomorrow to see if mine is all goofed up. Too lazy to do it now being tucked in bed.
The setting change didn’t help me but the lift seem to help.
Help.
Yep, just checked my trailer settings and mine was at a +5. I didn’t go out for a drive yet to test, but maybe later I can head out and test. Weird how it got changed. Only thing I can say is that maybe the button got bumped when I was cleaning, but that’s usually when the truck is off.
Just to update everyone: spent my entire day running errands all over the valley. I watched the gain setting on my EVIC to make sure it was staying at 0. Shifting was butter smooth and the truck had the old pep back. I really believe this fixed it.
I have no idea how that trailer setting got changed, and I did notice a marked difference in transmission performance the past couple weeks, ever since the day I got the inspection done. It was like it would shift too early, go into Eco mode and bog down. Now it really peps up and accelerates from the light.
Only change in conditions was it was in the 60s here in eastern PA today, so I don’t know if it behaved better because of the ambient temps.
Help.
One thought I had was did you put bigger tires on with your lift? If so, did you recalibrate your Speedo? I didn’t recal mine right after bigger tires, but the day I finally got it done, the shifting was way different for the good.
Maybe its just me, but I am having a hard time wrapping my head around the Trailer Brake Controller solution. I thought that this was a circuit dedicated to electric trailer brakes, but some of you are indicating it could be tied into potentially the tranny circuits, or maybe PCM?
I was thinking the same thing and was just as skeptical…but when i noticed a definite change i behavior in my transmission shifting, I went to this board and this thread is what I found. So I figured I would check and my gain was set to +5. Returning it to 0 and the truck went back to the way I’m used to.
Im wondering if maybe somehow it is tied into it, almost like the tow haul mode the truck shifts differently when engaged. I mean one day of driving around doesn’t mean much, but I ll continue to monitor and see if anything changes.
Interestingly, I seem to be unable to change my Gain. Pressing any of the buttons brings up nothing in the display. In my Uconnect Trailer Settings menu I can choose which number trailer, and can name trailers, but there is no option to actually pick the type of braking. I am now wondering if my Trailer Controller is unplugged, or maybe has a blown fuse. I have not towed a trailer with electric brakes yet, and the Controller is factory.
Try holding the brake pedal down while the truck is running and then changing the gain.
I haven’t recalibrated yet. I will soon and see if anything changes. It shifts fine now and Speedo is only off 2-3 mph
Been struggling with the same, trying to think of anything it could be. I tow with my truck. Just checked the gain after reading this thread, it was at 3.5. After adjusting to 0, I went for a drive and immediately could tell the downshifting was smooth again. What in the world! Never would have guessed they're in someway tied together. We'll see if change stays or if the rough downshifting comes back. Thx again to OP and @Nable486 for dropping their findings here. Super helpful, even years after OP.
This is very interesting. I've been experiencing similar transmission issues. I'm going to double check my gain and see if it changes anything.
I'm glad this thread was brought to the top again! If this improves my shifts I'm going to be thrilled. I will report back with my findings.
Thanks Stephen.overholser.
This is very interesting, I adjusted my trailer brake gain from 5.0 to 0 and I believe this has improved my shifting as well. I have no idea why the trailer brake gain would alter the way the truck shifts. You would think this would only change the behavior in tow haul mode.
I just wanted to post an update. I think this might have improved my shifting from rolling but I'm still getting the clunk and harsh shift into 1st when taking off from a start. The only thing I can figure is someone said the E Torque trucks shift into neutral while at stop lights and then its banging into first when I take off.
Hello Everyone,
I just wanted to bring this thread to the top again. I'm at 30k miles and now that the weather is heating up the harsh starting when moving from a stop as described in previous posts seems to be more common when hot.
I'm unsure if this is due to the E torque programming shifting the transmission into neutral while stopped and it slamming into gear to take off or if its due the E torque "assisting" during take off giving a jerky feeling. As I mentioned previously sometimes during take off I've heard some sort of slipping noise. I suspect it's either the E torque belt slipping or making noise or the transmission clutches.
Every time I brought it to my dealer it looks like they do a 2 minute test drive and blast it around the block and say it's fine. This is an issue that only occurs when gently leaving a stop but the shutter is harsh enough that it's alarming. Under heavier throttle everything seems to be fine, this is an issue that only happens during light throttle, light acceleration from a stop.
I was wondering if anyone else has experienced a similar issue or has found a solution.
