Wheel Brands/Models That Fit the 5th Gen Rebel
U
User_21361
Guest
with the dethloff skid plate do you have some pictures of it on under body?
Here you go
REBELmtnbiker
I've got Fuel Rebel 20s. Wanting to change from Nitto Ridge Grappler 305/55 to KO2 35x12.5. Will they fit? Or am I better off with the KO2 295/65? I really like the width I've currently got, but also looking to fill in the wheel wells a bit more. I found a software mod for the air suspension that the dealer can perform to lift the front another 2". It's currently at the dealer right now and I'm waiting to hear whether they will do it and how much it will cost. Last option is the Revel/Daystar kit. 35x12.5 HAS to fit with the Revel/Daystar kit installed???? Right??? View attachment 72784
I doubt they do it for you. I had the same info and they refused to do it. Daystar and some fabbed up links were the ticket. The 20's look really good.
ReLLIK75
Yeah...never hurt to ask. The service manager did say that they would definitely charge me to do it if it's something that they decide they will do. But regardless of how I get the lift, will the 35x12.5 fit or am I better off with the 295x65 which is about an inch narrower but same height.
bobgnarley
West Coast
I'm not very fond of graphics kits, but I can't not say that this is one of the cleanest looking Rebels I've seen. Well done, Sir!
SilverRebel21
Fuel Tactic. 18 x 9 +1 offset.
Falken Wildpeak 285/75r18.
View attachment 70024 View attachment 70025
I'm having Fuel Trophy 18x9 +1 offset with Nitto Ridge Grappler 275x75x18 and a 1.5" front level kit (I have air ride suspension) installed in a couple weeks. Do you have a front or rear profile shot of your truck that shows how far the tires stick out in relation to fender welds? Also considering throwing the more aggressive looking 2500 wheel flares on there (apparently they install fine on the 1500 as well). Thanks!
SurfRebel20
Method double standard 18x9 -12 literally can't fit a business card between brakes and wheels which made balancing tough for the shops to figure out weight placement. quicksquarenew_2021411191112704.jpg
