0051 MAR
I have a take home work vehicle, so I don't get to drive my truck as often as I'd like to. I leave the dash came running since the truck stays outside. I was noticing that the camera shut off (power saving mode) after only 2 days or so. I used to trickle charge my Charger and that worked out since the battery was in the trunk and I always back in the driveway (better camera view).
I was looking for a way to trickle charge my Ram, but I didn't want to run a cord all the way under the hood. Then I had a thought...the 7-way trailer port. I checked and sure enough, the 12v pin stays active even when the truck is off. So I wired a trickle charger into a 7-way trailer connector. It works really well.
I'm not sure if anyone else has tried this before but maybe someone else will find this helpful!
