Hood heat shield removal
2020GraniteBH
Couldn't find anything in the search about this...Does anyone have any good tips/tricks for removing the heat shield under the hood so I can gain access to the ****ty washer fluid lines they installed on these trucks? Thanks, in advance for your help!
I just ordered replacement fasteners. Then they arrived I went to town using trim removal tools. I was mostly able to remove it without creasing it, but it wasn't totally pristine when I was finished. Here's what I used...
That's what I was debating on doing. Thank you! Did you have issues with the washer lines as well?
No, I needed to replace one of the "vents" on my sport hood.
Gotcha! I'm debating on just ripping the heat shield off and not even replacing it, to be honest, I can't seem to find the part number for those push pins.
