eclipse5302
 - Mar 5, 2021
I hope this is in the right area.  If there's a better forum to put this in, let me know.
I have a 2019 Limited with the 360 cameras. I lifted (leveled) the front, and wanted to calibrate the cameras. I have AlfaOBD and a bypass and have tried the camera calibration, but I can't seem to get it right.
You're supposed to start the calibration procedure, then drive slowly for a while and it will figure everything out. I have better luck when I drive along areas with dashed lines, or other things on the road that help the cameras figure out how to de-warp the image. I just can't get it right...they still look "wrong" even when they successfully calibrate.
Clearly there is an OEM procedure that must be followed, but I can't figure it out. Maybe a certain pattern they lay down, or something...
