Woolnerc
 - Nov 24, 2019
Thanks for the heads up..
Thinking of going the 9x20 0 offset..
But may order a bora 77.8 to 106.1 10mm spacer..only a couple hundred, and will give me a -10 offset.. that way its gives me alittle more stance.. but if i run into any clearance issues i cant just remove them and put in a set of hubcentric rings and be done...
Im ok with alittle heat gunning the wheel trim.. but dont want to touch the body work.. i also want to keep my weather tec mud flaps, so recon i will see how it all is with the 0 offset and how it lines up with the wheel arch first and then pop on the spacers..
Trying to poke the sidwalls past the arch and trim pieces but the tread just in line with the mud gaurds.. so have a very slight agressive stance but not trownibg road debis ect up the side my truck.
