Thank you! Picked up a pair of these and HUGE improvement. Great upgrade for 30 bucks.I’m a fan of the 4 note horns. The FIAMM A-F note are the loudest horns that are DOT approved (133db IIRC). I can’t find the exact part numbers I put on my Land Cruiser without removing them, but here’s one of them. A lot of people scoff at non air-powered horns, but I’ve seen people jump inside their cars when I’ve hit my 4-note horns, so I know they’re pretty loud.
Edit: here’s a couple pics of what I can see behind the grill. Keep in mind these are about six years old and the truck is a 1998.
It’s super easy as long as you don’t do 4 horns like I did on the Land Cruiser. The supplied wire is a ground wire that goes from a negative terminal to either the horn mounting stud (if mounting to metal) or a good grounding point if mounting the horn to plastic. Add a female spade to the stock power wire and attach it to the horn positive terminal.Ekaz.....how hard/easy was it to install these horns? Any advice?
Thanks
Awesome...thanks for the advice/help. I dont want a train horn but I do want something to get peoples attention when need be.It’s super easy as long as you don’t do 4 horns like I did on the Land Cruiser. The supplied wire is a ground wire that goes from a negative terminal to either the horn mounting stud (if mounting to metal) or a good grounding point if mounting the horn to plastic. Add a female spade to the stock power wire and attach it to the horn positive terminal.
If you want to do more than 2 horns, you’ll overload the circuit if you hold down on the horn for more than a couple seconds. In that case, you’ll need to add a relay.
Yes, there are 2 horns.Do I take it that there are 2 horns on the truck already? Not like its something I go looking at.....lol
Thanks....just ordered 2 so will see how it goes. Thanks for the help.Yes, there are 2 horns.![]()
